al sharp 1642 cs
+ More Options
Posts
  • kisha
    • Jun 2025
    al sharp 1642 cs
    I have a code that keeps blinking, it is H 4. I called technical support and they told me that I must have had an electrical short and that the unit would need to be serviced. They had me unplug unit and plug into the wall since it was on a surge protector. Then they walked me through what they called resetting the unit, but it did not work. They told me that I would need to send the unit to them. I just want to be sure before I send this unit to them which will cost me about $70 because it is so heavy. Please any advice would be helpful. If someone has a way of removing the code and reseting the unit.
    Thanks Kisha
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Code is a fuser unit temperature issue. If the reset did not work then it needs to be taken apart and fixed or a new one put in. If you are not a tech then I would suggest calling one.
    • kisha
      sharp 1642
      I have another problem. I am receiving a code L 1 that keeps blinking. Is there a reset code for this error message.
      Thanks in advance for any help you may provide.
      • chakiris
        • 22
        you may have a busted thermostat in the fuser section if it will not reset thru the usual reset procedure.
        • chakiris
          • 22
          blinking L1 might be caused by the locking mechanism just below the scanner. Another cause could be your main board defect. Sharp has a technical bulletin regarding this problem.
          • Copybob
            I have found that the lubricant will get stiff on the scan rod. Try cleaning it with alcohol. The shipping lock will also cause this problem, I usually pop them off with a screw driver.
            best of luck!
            • juan contreras
              • Apr 2007
              • 6
              the soloution L1
              please go there http://olsonbros.com/sharp/support/p...53_ccd-mcu.pdf
              new brody
