AR-M207 E7-11
  • BMSInc95
    • Sep 2011
    • 66
    AR-M207 E7-11
    I have one that gets code 90% of the time when USB scanning. We have replaced ccd and updated firmware multiple times. Anyone know if the copylamp voltage can be increased or any other fixes. Thanks.
  • Horologydoc
    • Jun 2011
    • 61
    Re: AR-M207 E7-11
    Clean and lubricate the scanner rail. Also check your white reference strip underneath the glass.
    • Dark Helmet
      • May 2009
      • 835
      Re: AR-M207 E7-11
      I think there was a tech tip on this along with a firmware upgrade that corrected the code popping up.
      • Horologydoc
        • Jun 2011
        • 61
        Re: AR-M207 E7-11
        Good call Lawrence.
        Bulletin Number: MFP-SB-137
        Models: ARM162, ARM207
        Date: 10/7/2008
        Priority/severity: Medium
        Summary: Subject: ROM Version Upgrade (December 2006).
        Description: The firmware for the above model has been upgraded from December 2006 production.
        Executed from the production in December, 2006
        Model: AR-M207
        ROM Control No: B03
        MCU: V02.05
        IMC: V03.00
        PANEL: V12.00
        FAX: V2.10
        Model: AR-M162
        ROM Control No: B02
        MCU: V02.05
        IMC: V03.00
        PANEL: V12.00
        FAX: V2.10
        Corrections made:
        1. The operating margin for occurrence of E7-11 error (Shading trouble /White correction) has been increased.
        2. Since the E7-11 error may occur due to fogging of the reflector, the E7-11 error detecting level has been decreased.
        • BMSInc95
          • Sep 2011
          • 66
          Re: AR-M207 E7-11
          Performed bulletin. Just replaced copy lamp, reflectors and white sheets. Did a white ref adjustment. before it was 167 and was getting error now its 181 no error. has been working now for 3 days with no more errors. Copy lamp looked a little burnt on the ends. Thats were I'm putting my money.
