Fax over digital phone line(MXFXX1 & 2 and ARFX8 & 12)
  • perrychilds
    • Dec 2011
    • 23
    I have MXFXX1 & MXFXX2 and ARFX8 & ARFX12; I was wondering if they are able to fax over digital lines. I understand that there used to be issues because VoIP were designed for speech. Nevertheless, I did not know if Sharp or someone else out there had fixed most issues with digital lines and VoIP.
    The reason I ask is I have a customer looking into buying a machine and he has a digital phone line and I wanted to make sure that it was possible to reliability send and receive faxes on the machine.
  • mojorolla
    The Wolf
    • 2616
    Re: Fax over digital phone line(MXFXX1 & 2 and ARFX8 & 12)
    This can be a pain sometimes, but I have found the following settings work very well:
    -set the baud rate to 9600 for TX and RX
    -turn off ECM
    -change the coding, from JBIG to MMR. It is slightly slower but more reliable.
    -with Sharp, make sure you use the two-line fax cord, not the four line cord.
