Sharp 1540cs again with the L-1
  • wecoyote
    The copier started doing the L-1 happy dance, and I don't think it's the scanner (but maybe).
    From what I've read, the code is for a scanner position error. However, the scanner on power up will seek home, go right one inch and seek home again. That's when it errors.
    I would think from this action (and I can slide the scanner to the right by hand and it will seek home properly) that it IS aware of where it is.
    Any suggestions as to what to trouble shoot, or what to replace?
  • johnbla
    • Apr 2005
    • 94
    Check the scanner cable...............
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
    • ZOOTECH
      Senior member of CRS
      • 3375
      The scanner rail/bar and bushings have to be extremly clean and lightly lubed.
      • DavidEtling
        • Feb 2005
        • 31
        Sharp 1540
        Have had several of these. Replace the main board.
        • wecoyote
          I had already checked the cable from end to end, and lubed the rail after reading everything I could find on possible causes including the shipping lock accidentally engaging. All is good, and with the belt off the scanner moves very freely.
          As mentioned, the copier seems to know where home is as it finds it if I slide the scanner to the right, and also re-homes after bouncing to the right an inch where it then errors.
          So my best guess is that the copier IS homing itself through the startup routine, but something does not know that. This happened after gradually getting flaky over a period of months.
          Unless someone else has any suggestions, I'm going with the mainboard as it's actions indicate a partial lose of logic communication.
          • Vlad
            • Mar 2008
            • 23
            Check the Scanner Latch (left side under the control panel). The fin there should be positioned parallel to paper movement. Oiling the shaft is a good idea (I've seen all these symptoms before. Check code 1-1, see if the scanner moves freely to the override position and back and the home position light is ON when it comes back. Good luck.
            • vincent64
              • 382
              scanner woes
              On these machines that have the scanner guide rod and use the drive belt system, the scanner rod needs to be cleaned, I use alcohol and a green scotch brite pad, to clean the guide rod, q-tips to clean the bushings out, you will need several, as you will find some gunk in them, and I use Reel X on the rod and bushings, run a line of the lube, and work it around the rod, use a clean q-tip and work some lube into the bushings, put it all back together, and check the opperation.
              • mthomp
                remove the scan rail ( from rh side) clean rail and very important the brass bushings in the scan unit. (use a q-tip)
