F2-39
  • bonnie750
    • 302
    F2-39
    Hello
    I've got this code on a mx2700. The manual says it's the process thermistor which has a problem, connection/harness maybe. Is this the thermistor on the lsu?
    Bill
  • Nachoman4life
    • Oct 2007
    • 212
    Re: F2-39
    Nope the lsu thermistor is F2-49, this is the thermistor in the bypass tray
    Where the heck is my spring hook?
    • rrksingh@gmail.com
      Re: F2-39
      In MX-2700G
      F2-39 is related to :
      Trouble content Punch dust sensor detection trouble
      Section PCU
      Case 1 Cause Sensor breakage, harness disconnection, finisher
      control PWB trouble (MX-FNX2), punch control
      Check and remedy
      Use SIM3-2 to check the operation of the sensor
      punch dust sensor (FPDD).
      Replace the finisher control PWB or the punch
      control PWB.
      • sharptech
        • May 2011
        • 40
        Re: F2-39
        F2-39 does relate to the sensors in the bypass. Go into sim 44-16. blow into the area on the bypass that has the holes to let the air in. Look at the values in sim 44-16 for temp and humidity. They should change as you blow into the holes. If they do not them measure the voltage at the pcu pwb for the temp and humidity. If they change as you blow into the holes the sensor is good and you pcu is bad. If the voltages do not change the senos in the bypass is bad or the wiring between the senso and the pcu is bad.
        TGG
        • bonnie750
          • 302
          Re: F2-39
          Thanks for the info. I changed the thermistor and so far no repeat.
          Bill
