Another funny print issue in mx-2300
  • DINGO
    • 661
    Good night friends
    I m again, another funny print issue.
    I have a mx 2300n that when i print a picture all colors print good, and all that is black was forgotten??
    -Well, this happens only with the pcl5 and 6 drivers, with the driver PS print ok??
    -in copy do not have any problem
    -Of corse the copier as .the latest firmware, and i try with the latest drives to.
    -I try to in another copier with the same firmware and with the same drivers, and no problem.
    someone as any idea, or had this issue?
    regards
  • bilyahn
    • Dec 2006
    • 1470
    Re: Another funny print issue in mx-2300
    Had something similar and changed the graphics mode from vector to raster in the printing preference - advanced tab to get the black to print properly. Slows the machine way down when printing! Was on an MX2300 using PCL 6 and printing pictures from a 4 megapixel sony camera, machine has just the standard memory that comes with it.
    Good luck.
    Bil
    • DINGO
      • 661
      Bil.. thanks about your coment, monday i go to try.
      But my confuse is because i try in another similar copier, with the same firmware , options
      drives and the same picture, and no problem, i do not understand?
      for exemple i am testing using a image that cames in default in the w7 with the name "desert", all that is blak in this image was miss.
      • bilyahn
        • Dec 2006
        • 1470
        I can't really tell you why it worked on this copier and my solution may not be the correct one for you. I did not try to print the image on another MX2300 as we only have a few of these and none close together. Our problem was only on certain image files that the client wished to print not all color prints or images. Do you have a scanned image for us to look at?
        Have a great weekend.
        • DINGO
          • 661
          Bill, y test the copier with a image that you can get it, in a default images, in w7, or w vista, with
          the name (desert).
          But, i tested to another another mx 2300 and no problem.
          • DINGO
            • 661
            No sucess.
            i am testing with this image
            • igi
              • 1507
              Hi
              does it print OK direct from usb?
              does it print from laptop or other pc?
              good luck
              • DINGO
                • 661
                If i sent the image to a usb drive, and print directly, prints very good
                from anothers pcs, or S.O. gives the same error.
                thanks
                • igi
                  • 1507
                  Hi
                  usb prinst perfect= no drivers involved
                  1-delete current drivers reinstall the latest ones
                  2-on the mfp pwb reseat all memory modules and flash roms +eeproms
                  good luck
                  • DINGO
                    • 661
                    hi
                    well, i do not understand why???? but i already fix the issue using an old version pcl5/pcl6 drive from 2007.
                    with this drive the copier prints good, with the news latest drives do not work.
                    I am confused because i have anothers mx2300/2700, that work good with the latest drives!!!!!!!!: Confuso:
                    • bilyahn
                      • Dec 2006
                      • 1470
                      Congratulations. I'll have to remember that since I normally update to the latest!
                      Bil
                      • DINGO
                        • 661
                        regards
