mx 2300 SM 44-13
  • DINGO
    • 661
    mx 2300 SM 44-13
    hi
    Good morning
    i try execute the sm 44-13 (mx 2300) for change the value that was in "21", in pcs_pc ld adjust and always get error
    Some help i m glad.
    thanks
  • igi
    • 1507
    Re: mx 2300 SM 44-13
    Hi did you use the special tool for the adjustment
    if yes clean the sensor or replace, or swap to veryfy
    with its twin brother.
    cheers
    • bilyahn
      • Dec 2006
      • 1470
      Also clear you procon information with sim 44-27 before you start your calibration procedure.
      Good luck.
      Bil
      • DINGO
        • 661
        thanks igi, i do not have a special tool.
        Thanks bily..
        • harleyrider
          • Oct 2011
          • 348
          You need the jig to run this simulation. The sensor reads the gray patch on the jig. Keep the jig clean.
          • DINGO
            • 661
            ok, i already understand, but i haven`t jig.
            thanks
