"printer offline" ?
  • Dark Helmet
    • May 2009
    • 845
    #16
    Re: "printer offline" ?
    Originally posted by Buddy
    Thanks everyone. Turning off the SNMP did the trick!
    NOW, the only problem I'm having is the FK3 maintenance will not turn off. I went into SP24 and tried resetting ALL of the counters, since the fuser web counters didn't didn't get rid of it.
    The web has totally run out. There is a metal bar and 2 contacts that touch it. The web seperates the the contacts from the bar. When the contacts touch they signal the web has run out. On the back of the fuser behind a thin plastic cover you will see 2 wires going to a connector. Just unplug that connector until you get the web replaced.
    • Buddy
      • Aug 2009
      • 285
      #17
      You da man, Lawrence. I really do appreciate all of your help-thanks!
      • Buddy
        • Aug 2009
        • 285
        #18
        Thanks again everyone. Copier is up and running and everyone is happy. Turned off the SNMP, repalced the web, and reset the counters. All is good...whew.
        Now, I just have to figure out how to get it to scan to a MacBook Pro. I'll start a new thread. THANKS AGAIN!
