mx-2300 44-26 error
  • DINGO
    • 661
    mx-2300 44-26 error
    hi
    i have a mx 2300 that when i execute the s 44-26 i get a result error k;m;c;y?
    can anyone tell me something about?
    thanks in advance
  • Dark Helmet
    • May 2009
    • 853
    Re: mx-2300 44-26 error
    Im guessing the machine can't read the half tone patches on the belt. Have you cleaned and recalibrated the Procon sensors with the jig? Try running 44-2, 44-6, then 44-26 after cleaning and recalibrating with the jig and sim 44-13.
    Are solids ok looking when you print?
    • mojorolla
      The Wolf
      • 2626
      SIM 44-27 to clear the value, then 44-26 to set a new value. 44-13 is used with the jig.
      • igi
        • 1507
        Error" message when performing Sim. 44-26 (Forced Execution of Half Tone Image Correction)
        Cause: Half tone image correction is outside of the operating specification.
        Perform Sim 67-24 (Printer Auto Color Calibration) to bring the machine closer to specification, which should then allow Sim 44-26 to be completed without error.
        good luck
        • DINGO
          • 661
          good luck
          thanks all.
          infortunaly i do not have the calibaration jig, but i do what igi post and now the copier was very good.
          regards
          • Dark Helmet
            • May 2009
            • 853
            Better order one up!
            Jig part#
            UKOG-0318FCZZ
            • DINGO
              • 661
              thanks lawrence
              • DINGO
                • 661
                Hi
                i have another mx-2300 with the same error, i do the same procedure , but in this case no sucess.
                any idea?
                i already ordered the jig, and y try perform the 44-13, i hope this fix the error.
                thanks friends
                • Munter
                  Member
                  • Jul 2011
                  • 23
                  good luck
                  Necroposting to say this helped me out of a situation with a non-compliant copier. There are still some of these relics out there and this advice might apply to other models too.
