mx-6200n f2-02 error
  • xerotolerant
    • Mar 2012
    • 19
    Hello everyone, me again. My mx-6200n decided to up and die last night. It makes an odd rattling noise after powering, with the message "toner replenishing" and then pops up with that message.I read that that means that there is something wrong with the developing unit or something. I have no idea how to trouble shoot the problem.Any ideas anyone?
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: mx-6200n f2-02 error
    From the manual:
    F2-02 Toner supply abnormality (K2)
    Trouble content Toner end with the remaining quantity of 25% or more.
    The toner supply time exceeds 5 times as much as the specified time.
    Section PCU
    Case 1
    Cause Toner motor section connector harness trouble
    Check and remedy
    Check the connector connection of the toner motor section.
    Check the connector harness (TM) connection to the main PWB.
    Case 2
    Cause Toner motor and toner density sensor trouble.
    Piezoelectric sensor abnormality
    Check and remedy
    1) Check the toner density sensor output.
    (SIM25-1)
    2) Check that the toner transport pipe is not
    clogged between the toner cartridge and the
    developing unit. Replace the toner cartridge
    (CRUM) if necessary. Intermediate hopper
    replacement
    3) If replacement of the toner cartridge (CRUM)
    does not clear the trouble, check the
    developing unit.
    • bonnie750
      • 302
      sounds like the coupling on bk2 has fallen off. remove bk2 and see if the coupling which rotates the bottle is still in place, you may be lucky and fit it back into place
      bill
      • xerotolerant
        • Mar 2012
        • 19
        Hello thanks for your responses.
        Akitu
        I would like to try some of the mentioned remedies. I ran sim 25-1 it seems to run fine with no errors as a result. what to the numbers mean?
        When I run the calibration on the K developer in 25-2 I get the message trouble with the error EE-EU. Do you have any idea what the remedy for this is (if there is one) ?
        I'm attaching a picture of the area where the sound is coming from. It seems as though it can be opened, but I don't seem to be able to open it.
        When standing directly in front of the machine it literally sounds like the sound is just behind the blue area.
        bill
        Hello Bill, thanks for responding. Umm, is the coupling the plastic part with the blue connector with electronic contacts on it? If so that seems to be on.
        • bonnie750
          • 302
          the coupling rotates the bottle item 11 section 56 part no.ncpl-0084fczz. if this has fallen off the compression spring behind will be floating around in there somewhere.
