Sharp MX-4501 jams when duplexing 22-06 shows FIN_TIME error.
+ More Options
Posts
  • TechGeek
    • 158
    Sharp MX-4501 jams when duplexing 22-06 shows FIN_TIME error. This only happens when when duplexing. So far i have cleaned rollers, lubed bushings, tighten up springs by removing a few loops of the spring, made sure all solenoids/clutches are functioning properly. Any ideas would be helpful.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp MX-4501 jams when duplexing 22-06 shows FIN_TIME error.
    It makes a difference if it is an inner finisher or the large roll up finisher.
    • TechGeek
      • 158
      Sorry i did forget to mention which one it was. It is a MX-FNX1 inner finisher.
      • ZOOTECH
        • 3375
        "Finisher paper clearance abnormality JAM"
        Try adjusting the solenoid for the reverse gate in the finisher - the paper might be hanging up on the gate.
        Also, from a tech tip: Cause: Increase tension to MX-FNX1 return spring (Part Guide section 11, item 11).
        Solution: Finisher entry gate on MX-FNX1 (Part Guide section 2, item 18) was sticking.
        • Horologydoc
          • Jun 2011
          • 61
          I had this issue on one of my machines with a fin_time error. Ended up being that the fusing belt was floating too much and causing the issue.
