H2-00 (AR-5127)
  • sharpmind
    • Sep 2009
    • 478
    H2-00 (AR-5127)
    Can someone tell me the program mode in order to reset the H2-00 code. I can't remember if #, *,C, * (simulation 14) is the exact program mode for this machine.It's been 5 years that I handled this kind of machine. Is there also program mode which blocks the user to enter the program mode? Thanks!
  • JustManuals
    • Jan 2006
    • 9808
    Re: H2-00 (AR-5127)
    This Parts & Service Manual and the Service Handook can now be purchased for $12.77 and downloaded immediately after payment from
    http://www.justmanuals.com
    Paul@justmanuals.com
    • certifiedxeroxtech
      • Nov 2009
      • 27
      Re: H2-00 (AR-5127)
      You have to reset fuser errors with simulation 14. Press P * C * then 14 then Start. If not then replace the fuser.
      SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
      Also check thermal fuse, if defective replace.
      "prepare your contingency plan as always"
      • sharpmind
        • Sep 2009
        • 478
        Re: H2-00 (AR-5127)
        I tried it but I am not able to get into to the program mode. I thought it was blocked by the other technician.In fact, the only problem of the machine is jamming. I removed the fuser to check the fusing drive gear if it is still good. When I put it back the fusing connector got loose that is why it showed H2-00.I know that it has to be reset only but I was unable to enter into the program mode.
        • igi
          • 1507
          Re: H2-00 (AR-5127)
          Hi
          try
          # INTERRUPT C INTERRUPT
          and make sure the mfp is in the copy mode
          cheers
