mx-2300 question
  • DINGO
    • 661
    mx-2300 question
    Good morning, friends.
    Can give any idea, why some mx-2300, as copies more bright than others?
    I have in mi workshop two mx-2300, and one have much more bright in the copies than other.
    The two copies as the same code adjust, and i try change the fusion unit, and is the same result.
    Or, in other words, how i can adjust the brightness of copies?
    regards
  • lky1978
    • Mar 2009
    • 483
    Have u change lsu?beware of secondary transfer unit frame broken
    • DINGO
      • 661
      Re: mx-2300 question
      No problem with the copier, only as less bright than the other, and if i was trying to improve brightness.
      thanks
