Sharp ar 5320
  • sjinachandran
    • Jun 2025
    Sharp ar 5320
    Dear friends,
    I have faced the problum of very light copy due to low toner in developer, at the time replacing the developer it works good after 200 copies this problum presist , but i have tested with another machine it works fine. i dont have any programes in my service handbook. how to reset the toner value in this machine.
  • lky1978
    • Mar 2009
    • 482
    Are u using compatible toner?compatible toner a lot of trouble.
    • igi
      • 1507
      Re: Sharp ar 5320
      Originally posted by sjinachandran
      Dear friends,
      Hi try using this
      sim 44-40
      Setting of rotation time before
      toner supply
      Used to set the time interval between start of rotation (ready) of the main motor and start of toner
      good luck
      • Arcking1968
        • Sep 2011
        • 39
        Re: Sharp ar 5320
        I've encountered the same. Twice I replace the developer the third part I replace is the main board. The problem didn't return.
        • KM7155
          • Aug 2008
          • 145
          Re: Sharp ar 5320
          Hi Guys,
          i have a sharp AR5320 showing "d" after it switch on.
          the machine not moving at all, the error appear few second after it switch on.
          any idea?
          • igi
            • 1507
            Re: Sharp ar 5320
            Originally posted by KM7155
            Hi Guys,
            any idea?
            hi
            d means its in the download mode
            reflash firmware. if thath does not help replace main pwb
            good luck
