Sharp MX 2301 blank copy
  • geltrons
    • Apr 2007
    • 37
    One of my customer (ship ) is having Sharp Mx 2301 multifunction copier.
    When the "waste toner full" message came they removed,cleaned and
    washed the waste toner bottle, installed it back. But while printing or
    copying blank copy page comes out. no error message is displayed
    scanning works Ok
    Please help with your expertise
    regards
    Thomson
  • schotschen
    • Nov 2011
    • 33
    Re: Sharp MX 2301 blank copy
    Hey Thomson!
    You do not accidentally loosen the blue screw how holds the Transport Unit?
    (Shown in Service Manuel Appendix 9-9 Fig.3)
    If ITB is not locked Machine will "Print" Blank Pages.
    Cheers!
    • bilyahn
      • Dec 2006
      • 1470
      What have you done or replaced so far? What does your sim 64-5 test print look like?
      Good luck.
      Bil
      • geltrons
        • Apr 2007
        • 37
        Thank you very much for your comment/suggestions.
        Frankly, i haven't inspected the machine yet since it is on board the ship
        anchored few miles from the shore.
        I may get few hours to inspect and repair the machine, but i do not
        have any idea about the subject copier, no service manual, actually i have
        not seen one (This model sharp is very rare in this part of the world) that is why
        i wanted your expertise
        Thanks and regards
        Thomson
        • mojorolla
          The Wolf
          • 2608
          Like bilyahn stated, printing from SIM mode is great for troubleshooting. If internal prints are also blank, check the following:
          -Laser unit, no laser, no image.
          -High Voltage Board. These have a few dinky plastic clips holding the bottom of the board to the frame. The board comes loose, loosing contact and causing blank prints.
          -The IT belt cam. If the cam does not turn, the FTR rolls never put an image on the belt. If the waste toner filled up too soon, this is a good indication of a bad cam.
          • ledoux
            • May 2009
            • 75
            Some of the Sharps(Can't remember about this one in particular) when you removed the waste toner bottle it closed the shutters on the laser. I've had the lever get stuck in closed position a few times so it would make blank copies after it was emptied or replaced.
            “Boring damned people. All over the earth. Propagating more boring damned people. What a horror show. The earth swarmed with them.” Buk
