MX 3501N won't print color from a 64 bit machine
  • Buddy
    • Aug 2009
    • 285
    Hi all,
    I'm unable to get a customer's MX3501N to print color from a 64bit laptop. I have all the print access settings configured the same way as other laptops that aren't 64bit and those print fine. Am I missing something?
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX 3501N won't print color from a 64 bit machine
    Originally posted by Buddy
    Hi all,
    Are you using the 64 bit driver? PCL6 or PS? Do you have B/W checked in the colour tab of the printer preferences?
    • Buddy
      • Aug 2009
      • 285
      Yup, using the right driver and have the color checked. When we try to print color it just goes into the either.
      • schotschen
        • Nov 2011
        • 33
        Checkt for any User Authentications
        • Akitu
          • Oct 2010
          • 2595
          If there was no user authentication it wouldn't print at all, just disappearing into the netherspace.
          Sounds like you may have a corrupt driver, have you attempted to reinstall it?
          • schotschen
            • Nov 2011
            • 33
            I have not expressed myself correctly... Excuse the misunderstanding!
            My English is not the best I think
            I thought that you can disable Color Prints in a user profile.
            For example, if the boss does not allow all his workforce to print in Color.
            I think that you are not wrong with your opinion to reinstall Drivers...
            • Akitu
              • Oct 2010
              • 2595
              Ah! Yes, you are correct. With user authentication enabled there are options to restrict certain users or groups of users to have B/W pages only. Might be another good thing to check out, assuming this machine has user authentication enabled.
              If not, then I'd go back to reinstalling the drivers and see how that turns out.
              • Buddy
                • Aug 2009
                • 285
                No, I haven't tried to reinstall the driver. Yes, authentication is enabled, but I set up this user to print color. I'll have to try a reinstall. Thanks
                • Akitu
                  • Oct 2010
                  • 2595
                  I believe a group setting will supersede an individual user. If you have an exclusive B/W group as well as individual settings you may have to set the group of the user to none.
                  Good luck!
                  • colgrimes
                    • May 2012
                    • 64
                    sometimes the program parameters override the driver parameters. make sure there isnt a color vs black and white/grayscale option in the program theyre printing from. i've had this happen before, it should be on the main print screen before going into the driver properties.
                    colgrimes
                    The Printer Guy
                    CopierCollin.com
                    Hybrid Honest Sales/IT
                    • colgrimes
                      • May 2012
                      • 64
                      colgrimes
                      The Printer Guy
                      CopierCollin.com
