MXM453N PPD2_N1 paper jams
  • redserv
    • May 2010
    • 307
    hello guys, i am at a client that are getting intermitant paper jams in tray 1 on a MXM453N MFP, i have been referred to TT20183, i did the modification for with the spring, and changed the paper orientation to 81/2x11R, when i check the jam history i am getting a paper jam at PPD2_N1,i cleaned feed rollers , transport rollers and stuff, but dont know what to do to reslove this issue, can someone kindly give me some advice on this?thanks in advance.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MXM453N PPD2_N1 paper jams
    I can't seem to find any references of a problem with this on sharpnet or ssap. Would you be able to share your bulletin? Also, have you considered the paper at fault?
    • redserv
      • May 2010
      • 307
      yea sorry Akitu, think i have it all wrong that TT, that i have in my previous post is not related to my problem, however i am still getting intermittant paper jams at PPD1, The Jam History gives me this PPD2_N1, any suggestions?
      • Akitu
        • Oct 2010
        • 2595
        Blow out your PPD 1/2 sensors with a can of air and see if your problem gets better, else I would try some different paper.
        • copyguy1
          • Jul 2011
          • 142
          Also make sure to clean refelective pads in right door for sensors. How manyy pages on this machine?
          • Nachoman4life
            • Oct 2007
            • 212
            Use sim 23 to check for repetitive jams. If cleaning the ppd2 sensor and reflects doesn't work, replace the ppd2 sensor, I myself have had several ppd2 sensors in the MX series (Color and BW) fail, usually a failing sensor will work for a while and will stop changing state when the sensor flakes out. If you can catch the machine in a repeat jamming state, test the sensor in sim 30, (open door, wave hand in front of sensor), make sure it changes state. Past that, remove the Registration unit and check for stuck labels or label residue, they love to stick behind the guides of the registration roller. If you are in a pinch, I've used registration sensors from the arm350,455, MX350 series as replacements (part machs) same sensor just leaded.
            Where the heck is my spring hook?
            • redserv
              • May 2010
              • 307
              hmm,the strange thing is, its only happens with the first cassette which has 81/2x11 paper, so i am thinking the customer paper can be an issue, there are2 other trays and they work perfectly, therefore the other paper trays are using the same paper path and the sensors, so i'll have to try some different paper today when i return to the customer.
              • Dark Helmet
                • May 2009
                • 865
                Ive also had that sensor fail as Nachoman said. Ive had a MXM283 go down, paper keeps jamming at the reg roller. You can test the sensor in sims, it works fine. I wiggled the sensor around, cleaned it off and it started working again. 2 days later it started to jam again.
                I think they changed the sensor from a long focus to a short focus. I can't find the bulletin but if i remember they changed the sensor and the little plate that holds the sensor as it's a bit shorter now.
