Sharp MX 2700 setup to scan using usb then shared how can this be done ?
  • yannii33
    • 121
    I have the sharp MX 2700 shared thru a pc on the network using usb is there a way to enable scanning to usb do i need sharp desk please advise
  • bilyahn
    • Dec 2006
    • 1469
    Re: Sharp MX 2700 setup to scan using usb then shared how can this be done ?
    You can use the GDI version of Sharpdesk or setup your TWAIN setting through your scanners and camera in control panel. If you used a GDI driver for your print setup then your scanner setup should go fairly smoothly as the scanner info is included with the setup. Just click on add a scanner and follow the prompts should find the device without any problems.
    Good luck.
    Bil
