Sharp MXM 200D Copy quality and feeding problems
  • tibbs
    • Aug 2008
    • 223
    Hello friends, i have a Sharp mxm 200d printing light and the toner is spilling when i check the dev unit it's not covered with toner entirely not sure what the problem is.
    On that same machine i have another problem with the first tray. It's saying when you try to make a copy : Check paper path. There is no paper in the paper path and the machine feeds properperly from the other trays. Can someone give some assistance on these two issues
    Thanks much
  • Horologydoc
    • Jun 2011
    • 61
    Re: Sharp MXM 200D Copy quality and feeding problems
    Thanks much
    For your light copy issue replace your developer and makes sure the bias is run properly(door open until you're in tech mode ect).
    For the check paper path one I've seen where customers have partially cleared jams and scraps of paper get into where you cannot see them by opening the side door. Remove the trays and look around the paper path actuators from underneath.
