"Flat sopt" on rollers
  • redserv
    • May 2010
    • 307
    hello guys, i have seen this issue before "Flat Spot" on fuser rollers, i have changed out an entire fusing unit a couple weeks ago, the customer called for paper jams yesterday,when i arrived at the client site i removed some paper that was stuck in the fusing unit, and noticed when manually turning the fuser drive gear that rollers felt like it had a "Flat Spot"i have seen this problem before, but not sure how to rectify the the problem, the MFP is MX-623N, thanks in advance guys.
  • vincent64
    • 382
    Re: "Flat sopt" on rollers
    I have seen them rollers flat spot, not sure why, I thought Sharp had figured it out a while back after the AR-350/450 models, I think its the foam like stuff under the outer cover, all that is over a hollow roller, the old rubber rollers never did flat spot as I recall.
    • mojorolla
      The Wolf
      • 2639
      Here is Sharps solution for flat spots on the AR-350/AR-450:
      "The flat spot can be recovered by setting the Pressure Levers to position where pressure
      is released and let the unit sit for a day or so or install it into a machine to warm up and
      the flat spot will smooth out."
      Awesome!!
      The 6201 and 7001 are notorious for this. If it sounds like a galloping horse, it's a flat spot. We always have these as a car stock item due to the high failure rate. There is a way to adjust the amount of pressure applied by the pressure release system using soft switches. However, there is no documentation for this from Sharp.
      Awesome!
      You can adjust pre heat mode setting. When it enters pre heat mode, the pressure is released.
      • redserv
        • May 2010
        • 307
        you're the man i tried the fix and it worked, thanks again buddy and again and again :P
        • igi
          • 1507
          Hi for all of you flat spotters out there
          please remember in the future its possible to avoid flat spots on the folowing models
          all models with soft power off switch.switch the soft swith first
          then the rollers will have time to seperate
          cheers
