question on sharp MXM450 cross to Oce 4512
  • toolkittoter1
    • Aug 2025
    we are using the oce 4512 in schools and don;t want to replace the hard drives when thay fail. how do you turn them off so machine will work.we have a few machine that are working with same set up as the ones w/ harddrive but they don't have one. removing the hd we get a message hhd failure. we have the book for the sharp mxm450 but can't find a code for it. we were told by an oce guy that we need to turn it off but he couldn't renemebr how. any you sharp guys know?
  • lky1978
    • Mar 2009
    • 483
    Just order a new ide harddrive atleast 40gb .no system software require.just plug and play.
    • toolkittoter1
      Re: question on sharp MXM450 cross to Oce 4512
      The problem the copier is having is sometimes, after powering up, the LCD displays the Enter Product Key for Network Scanner message. Even when we enter the correct numbers (off the back panel of the copier), the copier says the key is incorrect.
      Sometimes, performing a hard drive reformat will clear this message and the copier will come to ready. What we need to know is how we bypass this Network Porduct Key screen when a reformat doesn't clear it. On this model of copier, once the screen pops up, you can not even copy off the glass. Previous versions would only challenge you for a key if you actually tried using the scan feature.
      This product key registration problem basically renders the copier useless until a fix can be found. I have not found any service code that cancels this screen.
      • lky1978
        • Mar 2009
        • 483
        Try to reseat both boot rom and main rom, nic card.hope can help you.
        • jpcopy
          • Apr 2006
          • 256
          BUMP
          reseting didn't help also having same problem on a oce 3511 cross to a sharp arm 355
