Sharp ar-m451 pod1
  • DINGO
    • 661
    Sharp ar-m451 pod1
    hi friends
    can someone give me same information if this copier or options, as another sensor like the pod1?
    Is not the same from ar-m450 pod1, and in this case , i know that the spf sensor works in the pod1.
    any information i m glad.
    regards
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp ar-m451 pod1
    All of the sensors in the turnover assembly are the same also. I have used POD sensors from multiple generations of machines, even the color MX series 2300 - 4501. They're all the same sensor.
    Good luck.
    Bil
    • lky1978
      • Mar 2009
      • 483
      Dingo, the arm451 pod1 sensor not same with arm450, but you can put arm450 sensor on the arm451. Just swap sensor wire position, blue to blue, grey to grey and brown to brown.
      I done many units.
      • DINGO
        • 661
        thanks a lot my friends
