export settings from MX-4501N To MX2610N
  • redserv
    • May 2010
    • 307
    hey guys i have a client that we just upgraded there MFP from MX-4501N to MX2610N, how can i export all the scan, webpage,doc filing from the previous model to the MX-2610N?thanks in advance,i really dont want to setup there network again
  • ZOOTECH
    Senior member of CRS
    • 3381
    Re: export settings from MX-4501N To MX2610N
    You can export Data Backup and Device Cloning from the Mx4501N which will be saved as a .bin file. You can then import the files to the MX2610N.
    • redserv
      • May 2010
      • 307
      thanks alot zoo, this is just what i wanted. appreciate it edit: one more question guys, will it work if its different model MFP's, like in my situation?
      • mansart
        • 852
        It will work. however if you plan on doing any tweaking to the op panel of the 2610, do the cloning first, otherwise all changes to op panel will be reset
