MX5111N New Setup
  • ZOOTECH
    Senior member of CRS
    • 3375
    MX5111N New Setup
    MX3501N@COPYLINK.NET_20120814_110356.pdf
    New setup and I'm having copy quality problems. Voided areas occur at 96mm intervals and 25mm wide mostly on front side, front to rear for all colors. Machine has latest firmware, LSU shutters are straight and move easily when solenoid fires, and calibration has been done (to the best it could be under the circumstances). Have changed the primary transfer unit with no help, reseated memory and SD cards, and switched drums around to no avail.
    ??? What am I missing ???
    Any help will be greatly appreciated.
  • mojorolla
    The Wolf
    • 2617
    Re: MX5111N New Setup
    I would be curious to see the 64-5 or 64-1 pattern 9 (full density of all four colors). We had 2 LSU units go and it did all kinds of odd things, including something similar. Pull open a door while its running and see how the image on the transfer belt looks. Have also had a few issues with fusers on this model.
    • ZOOTECH
      • 3375
      Will check that out Wed. and post image (getting advice from our friend downunder, also). Tks mojo...
      • ZOOTECH
        • 3375
        As you can see, hopefully, TC 64-5 is great; TC 64-1 #9 has a problem showing only in magenta, not sure what that is in the cyan.
        I'll be looking at a binding drum or dev unit later today.
        • ZOOTECH
          • 3375
          All dev units and drums rotate easily by hand; print out stopped mid way and image on primary transfer is the same as the printed page.
          • mojorolla
            The Wolf
            • 2617
            Do you use the powder for the drum side seals as well as the normal stearic acid drum powder? It makes a huge difference.
            Your black looks good, you could swap magenta for black and see if the defect follows.
            When was the machine made? Does it have the retrofitted DV lids?
            I am actually in Chicago for Polaris training this week so I'll take it to the experts and see what they think.
            • igi
              • 1507
              hi
              check the mechanism that drops and lifts the main belt unit.
              cheers
              • ZOOTECH
                • 3375
                I have not been able to check these suggestions out, been busier than shite. I will post when I find the fix.
                • ZOOTECH
                  • 3375
                  Re: MX5111N New Setup Update
                  The fix was to replace all four drums. They all must have gotten over exposed, somehow, at one time or another.
                  The repeating void at 96mm is the circumference of the drum.
                  Thanks to all for your help.
