Disabling Fax board
  • daiharrison
    [Error Code] Disabling Fax board
    Need to start using an old copier that became surplus to requirement but after switching it on I remembered that I had put it away broken.
    The machine is a Sharp Ar-m236 multifunctional copier.
    Upon switching it on i get the error code F6-88. Having looked this up, it states that it is a fax board error.
    I no longer require the fax and therefore removed the board and tried switching it on. I had a continuous beeping noise and then removed the RAM just above that board which resolved that.
    Hoping that it was that straight forward, I was soon disappointed.
    Need to know how to remove the fax board properly and if not, how to get passed the error code of F6-88 so I can at least copy and print.
    Any help is greatly appreciated.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Disabling Fax board
    There are 2 boards that you have to remove. The smaller fax PWB with the phone connections on it and then the larger board that it is connected to. When both boards are removed then you will be able to copy.
    Good luck.
    Bil
