Hercules Doc Feed trouble
  • ZOOTECH
    Senior member of CRS
    • 3375
    We just placed a new MXM850 and with less than 500K are having troubles with the doc feeder. As long as 3 or less copies are fed through the feeder, everything is fine (simplex or duplex). If more than 3 pages are fed, the forth page stops over SPPD5, 6 and 7 and gives a SPOD error. The page will stop exactly the same spot each time on the forth page - yes, the firmware is the latest and has been re-flashed again. We are about to replace the whole doc feeder at this time unless we have some help from you.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Hercules Doc Feed trouble
    Does it matter if you are doing single sided or two sided? Haven't seen this yet!!! Have enough problems with the 2 850's we have already! LOL
    Good luck.
    Bil
    Sorry just re-read your post! Stupid question on my part!
    • copyguy1
      • Jul 2011
      • 142
      My guess is it does this on all size of paper. Outlet?? We havwe a few of these out and neverr had this issue. You may want to check all connectors Good Luck
      • ZOOTECH
        • 3375
        I won't be able to look at this for awhile, busier than shite right now. I did get word from a reliable source who mentioned a sluggish sensor return spring is most likely the fault. I will post when I'm able to give a fix.
        • rainmaker
          • Jul 2011
          • 77
          what i would do first is to clean all the sensors in the doc feeder.there are two under the paper feed unit itself.they are photo sensors and are prone to get paper dust on them.good luck.
          • r3d343420
            • Aug 2012
            • 56
            Test all the sensors and clutches in SIM mode. Verify they are actualy working correctly. Is there any Lag when the three sheets are being fed? it sounds like from your description that there is a timing issue from either a faulty sensor or clutch, I have over 20 of these in my territory and have never had to replace a entire doc feeder. Good Luck
            • ZOOTECH
              • 3375
              We did switch out the feeder with our showroom machine to troubleshoot it away from the customer's location. All the sensors and clutches were checked out; when I get a chance, I'll add a wrap to the
              sensor return springs and update with fix.
              Thanks to all for your input..
              • ZOOTECH
                • 3375
                Re: Hercules Doc Feed trouble Update
                Update on repair; ran TC 7 with misfeed disabled and it fed a stack of paper; doc feed sensors were rotated to see if symptoms changed, still got SPOD_N jams;
                switched doc feed control pwb with a lease return (8 million copies) and it worked great.
