sHARP AR-M451N
  • DINGO
    • 661
    sHARP AR-M451N
    hI friends
    i have a ar-m451n that when is making some work, print, copy scan, if the costumer open the front o left door, the copier reboot.
    someone as sometime this issue?
    my best regards
  • JustManuals
    • Jan 2006
    • 9838
    Re: sHARP AR-M451N
    Paul@justmanuals.com
    • igi
      • 1507
      Re: sHARP AR-M451N
      hi
      firstly tell the customer not to open doors while the mfp is running
      ok now to the bussines end
      check and reseat any memmory modules
      reformat the h.disk
      reflash the flimware
      and check for any hi-voltage arcing isue like a badly worn drum
      cheers
      • DINGO
        • 661
        Re: sHARP AR-M451N
        regards
        • lky1978
          • Mar 2009
          • 475
          dingo, also need to check the boths earth spring located at ps unit
          • DINGO
            • 661
            Re: sHARP AR-M451N
            thanks
            • DINGO
              • 661
              Re: sHARP AR-M451N
              Hi friends
              The issue was solved, was the "count bytes lpr" in the print drive, when is enable, the copier take more time for print.
              I post here the solution, may be usefull for someone else.
              good night
              • DINGO
                • 661
                Re: sHARP AR-M451N
                Good night friends
                sorry, of corse my previus comment isn't for this post, i only saw the error know.
                Of corse the issue in this post is not soolved, and i post what i already do:
                -i changed the main, and print board, and hdd and memories.
                -i changed to, the main power suply
                -i changed the ful drum unit.
                -i changed the left door
                -the transfer and charge unit.
                -full ps roller unit
                -of corse the firmware is updated witj the last version.
                i do not know what i can do more, because the issue stay there.
                The copier is in stand by ready to copy, or stop becuase jam and so, when the door is open freeze and rebbot.
                regards
                ( some times give me e7-90)
                • CopierTechofOmens
                  Agitating Artificer
                  • 268
                  Re: sHARP AR-M451N
                  e7-90 can come from corrupted PCU flash ROM
                  In the AR-M355 the HVT was changed due to E7-90 and machine turning off and on
                  sigpic
                  • DINGO
                    • 661
                    Make sense,, i do it,, thanks
                    • DINGO
                      • 661
                      Re: sHARP AR-M451N
                      Hi friends
                      after a few days and a hard job, i found the issue.
                      my problem was that the copier when open the front or left door, imediatly reboot, and sometimes give me e7-90.
                      tthe problem was a bad htv board.
                      know i m tryng repair them because in my country is very expensive.
                      copytecho, thanks for you to.
                      i post here, becuase may be useful for someone more.
                      thanks
                      • ZOOTECH
                        Senior member of CRS
                        • 3374
                        Re: sHARP AR-M451N
                        Originally posted by DINGO
                        Hi friends
                        thanks
                        It's always good to see what the fix is for a problem, tks Dingo.
