2700N Noise
  • PCtech1
    2700N Noise
    I've been working on this machine lately that has been giving me a bit of trouble. The initial call was for noise, so I go check it out, and it sounds like a flat spot on the fuser roller. I come back to the shop grab a new fuser, go back put the fuser in and it doesn't fix the issue. I followed the noise as best as I could to the back of the machine. I opened the machine turned the power back on and listened to the noise again. The best I could narrow down the source of the noise was to the main drive area. I couldn't really go any further because of course I need the power on to hear it and when working in that area you need the power off. If anyone has any ideas I would be most grateful and I don't care what they are because I am stuck and anything helps.
  • brewster67
    • Jul 2011
    • 167
    Re: 2700N Noise
    I would use sim 6-1 to run the motors one at a time. When you figure what motor is on when you get the noise, you can then see what that motor drives. From there it is a process of isolating different sections. I have even removed gears to separate one part of a drive pack from spinning. Hope this helps.
    • JustManuals
      • Jan 2006
      • 9865
      Re: 2700N Noise
      Paul@justmanuals.com
      • sharpie
        • Feb 2011
        • 175
        Re: 2700N Noise
        We have had quite a few black developer units causing noise from the drive belt jumping on the back of the unit.
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2596
          Re: 2700N Noise
          Same as what Sharpie said. Easiest solution is typically to replace the whole DV unit.
