Sharp FO-dc535 with HSYNC message
  • axyun
    • Aug 2007
    • 1323
    Customer has called saying machine gets an HSYNC message and is unable to use machine but will usually recover after turning off and on. I have never service a machine for this. The H errors I have seen on Sharp are usually fuser errors but this I suspect may have to do with scanning. I did not see anything in a related service manual and since I was pressed for time and may need to show up this afternoon i thought i would post it here. I will look into the 2 areas I have mentioned but would appreciate any help . maybe by the time I get to customer there will be a response that can take me in right direction. Frank/Action Photocopy
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Sharp FO-dc535 with HSYNC message
    This is a LSU (print head) error. It the problem clears with a power off/on, it will soon fail completely. This is an old part number, but it may still be good - 0KW4571075200.
    Good luck.
    • JustManuals
      • Jan 2006
      • 9865
      Paul@justmanuals.com
      • axyun
        • Aug 2007
        • 1323
        Thanks Zootech. I did not see anything in the manual about this. Did I miss something? Frank
        • ZOOTECH
          • 3378
          No, you didn't miss it, it's not in the manual - there is a tech bulletin with the error codes.
          If I can find it, I'll send it to you.
