mxc311 repeating image from previous
  • ash_572
    • Oct 2008
    • 523
    it seems like its adding too much toner onto the paper.
    previously i changed the black drum unit and black dev unit. copies were running quite pale but prints were perfect. so i then did the colour calibrations set up.
    since then its repeating the image on to the next page here and there.
    is there anyway i can adjust it so it prints less toner onto pages???
    its had a brand new fuser. i dont mainly work on sharps.
  • mojorolla
    The Wolf
    • 2626
    Re: mxc311 repeating image from previous
    I would check the IT belt unit or the secondary transfer unit on the door.
    Could also try lowering the fuser temp.
    • Dustin(WOP)
      • 223
      I have had the same thing, took out the laser cleaned the polygon motor mirrors and problem is gone.
