Sharp mx-6201n scanning???
  • grandpapro50
    • Sep 2011
    • 18
    Just got a sharp mx-6201n and trying to set up for scan to e mail and scan to desktop --- any one know about this---we have optimum as our internet provider and all computers are windows 7 and xp--- thanks in advance
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp mx-6201n scanning???
    Pretty straight forward if you are using Sharpdesk software (should be a CD with version 3.3 in your user guides). If you like to do it from the machines web page you can access the user guide on that page and it will help you through the setup.
    Good luck.
    Bil
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      I try to avoid Sharpdesk if at all possible.
      Get your DNS info and verify as to whether or not they have an exchange server. If there is an exchange server, the copier will need its own address and password to pass objects through the server.
      Input all data into network settings of the web page and it's fairly simple at that point.
      Scan to folder needs to have the folder shared on the network first and foremost, and then the network path to the folder must be copied and pasted into the copier address book "//computername/directoryA/directoryB" will have similar formatting to that, be sure that anti-virus software doesn't block the copier from accessing.
      • grandpapro50
        • Sep 2011
        • 18
        dont have the software---but figured it out ... thanks for the info akitu and bilyahn
