MXM350 with L4-02
  • tomislav
    • Nov 2011
    • 30
    MXM350 with L4-02
    Hi,
    I have problem with Sharp MXM 350,show me error L4-02.
    The drum motor rotates when check on service mode.
    PLS help.
  • JustManuals
    • Jan 2006
    • 9838
    Re: MXM350 with L4-02
    http://www.justmanuals.com
    Paul@justmanuals.com
    • igi
      • 1507
      hi
      the drum unit is not clening the toner out propertly
      its accumulates and ads stress
      there were many tech reports about this problem
      the best things to do is
      1-latest flimware(firmware)
      2-service the drum unit
      cheers
      • CopierTechofOmens
        Agitating Artificer
        • 268
        They updated part of the drive unit back in September 08.
        Part Change [Section 4 Item 4] DV Drive Spring to Prevent L4-02, Blank
        Copies, Abnormal Noise and/or Void Areas.
        Details: The tension of the spring has been increased to prevent it from becoming disengaged.
        Symptom: L4-02, Blank Copies, Abnormal Noise, Void Areas
        New P/N:MSPRC2616FCZ1 DV drive spring
        sigpic
        • PASTech
          • Sep 2010
          • 192
          We have a a few of these type of machines. The biggest thing we find is that the waste toner gets filled up quickly, well before the toner needs to be replaced. Empty out the waste toner from on the toner cartridge, that would be the first thing I would check. This causes the Drum to lock because it is all driven by the same motor.
          Hope this helps
          What's Brown and Sticky?
          -A Stick
          • CopierTechofOmens
            Agitating Artificer
            • 268
            ... The MXM350 eats it's own waste and reuses it
            sigpic
            • PASTech
              • Sep 2010
              • 192
              What you mean? Aren't they like the ARM455s in that they have a toner/waste toner Cartridge combined?
              -A Stick
              • copyguy1
                • Jul 2011
                • 142
                TWo other things to look at. One is the dv box locking up Sharp had an issue for a while wherre tey had to change a bearing on it, they even sent me a couple of these. You might want to check your main drive for binding. How many pages on this unit?
                • CopierTechofOmens
                  Agitating Artificer
                  • 268
                  On many of the sharps it recycles the waste toner back into the toner supply.
                  sigpic
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    My understanding is there was a separation between the new supply and the waste toner - basically a "bag" that fills the area where new toner came from as waste toner fills it up.
                    But my understanding could be totally off on this.
                    • tomislav
                      • Nov 2011
                      • 30
                      Originally posted by igi
                      hi
                      cheers
                      I,update the firmware & service the drum unit,but i've still got L4-02.
                      • bilyahn
                        • Dec 2006
                        • 1470
                        If all of your components are moving freely (registration, developer, drum, main motor and fusing unit) then try replacing the charge unit. When does the L4 code appear? I have had each of the items above cause an L4 code at one time or another. Do you get the code when you run the MM in sim 6?
                        Good luck.
                        Bil
                        • copyguy1
                          • Jul 2011
                          • 142
                          The other thing you may want to look at is there is a small set of gears on the bach of drum unit we had a few of these get stripped off. How many pages on machine?
                          • tomislav
                            • Nov 2011
                            • 30
                            Originally posted by copyguy1
                            the other thing you may want to look at is there is a small set of gears on the bach of drum unit we had a few of these get stripped off. How many pages on machine?
                            hi,i found the problem,the grease on the gears in the drive unit was full of dirt,so the drive unit is turning hard.
                            Thanks for all reply's.
                            • gbfan
                              • Aug 2010
                              • 19
                              A MXM-350 and an ARM-455 use the same toner, and yes there is a wall between the toner waste and fresh/new toner. I just pulled the cover off to verify as I thought it was walled also, If not there would be paperdust and other contaminants making its way into the good toner.
