Imagistics 64 bit print driver for an IM3510?
  • Buddy
    • Aug 2009
    • 285
    I realize the 3510 is getting long in the tooth, but was hoping someone might have a suggestion. Thanks
  • bilyahn
    • Dec 2006
    • 1470
    Re: Imagistics 64 bit print driver for an IM3510?
    There is no 64 bit driver for this unit (at least not one put out by Sharp) but you should be able to use the windows update when you add a printer. Have done this with the AR207 and some other older machines.
    Good luck.
    Bil
    • lky1978
      • Mar 2009
      • 482
      i tried using sharp mx-m450u/n 64bit driver.worked fine
      • Buddy
        • Aug 2009
        • 285
        Thanks guys. That worked!
