witch sharp model is recommended for a +100K prints per month?
  • mad
    • Jul 2010
    • 25
    monocrome and with finisher...
    with new sharp model would you recommend?
    i'm a new sharp dealer... any ideas?
  • harleyrider
    • Oct 2011
    • 348
    Re: witch sharp model is recommended for a +100K prints per month?
    mx-m623 or 753. As per finisher it would depend on what you need- there is a couple for these models.
    • PASTech
      • Sep 2010
      • 192
      Agreed
      What's Brown and Sticky?
      -A Stick
      • mad
        • Jul 2010
        • 25
        are they reliable?
        thanks for the prompt response!
        • PASTech
          • Sep 2010
          • 192
          Originally posted by mad
          are they reliable?thanks for the prompt response!
          We put in two MXM753's last year into a large High School, we have had very little problems with them other than use induced jams or damage to fuser from the wrong transparencies.They seem to be pretty solid.One thing you need to do is plug the machines in for at least 24 hours prior to assuming they are good. We did get one of these machines in and it tested fine in shop and then a week later when we installed the HV power board was Dead. This according to sharp was a rare occurance with all machines where a board broke from the current running through a bad connection on that board. They said that one was we can make sure that it is good before you take any large copier is to plug it in for at least 24 prior. Doesn't stop the deadness but at least you don't tell the customer it is ready and then bam it is dead.This is not a slam on this machine, the ones in the school have done really well. Just seems to be a problem with circuitry when the machine get shipped way up north here.Hope that helps, I would say go ahead and sell them these machines! they are next generation, ARm550's which we have many out there pushing well beyond their lease. Solid Machines!
          -A Stick
          • copyguy1
            • Jul 2011
            • 142
            I think i would perfer the hercules machines we have at least 7 that are at 100k plus per month. All the supplies go past the recomened yields. Must replace feed rollers every pm. Most have the smaller finishers.
            • mad
              • Jul 2010
              • 25
              which models are the hecules family?
              • Akitu
                Legendary Frost Spec Tech
                • Oct 2010
                • 2595
                MXM850/950/1100...
                If you're holding out for a Hercules unit, might as well wait it out and grab a Hercules 2 when they become available.
                • copyguy1
                  • Jul 2011
                  • 142
                  They are available,just set up a 1204 in our office yesterday. The main body is pretty much the same. But they did use the aries touch screen. The new models are 904,1054,1204
                  • ZOOTECH
                    Senior member of CRS
                    • 3378
                    Originally posted by Akitu
                    MXM850/950/1100...
                    Agreed, but he may find "close out" deals from Sharp to clear out their inventory.
                    • Akitu
                      • Oct 2010
                      • 2595
                      Not sure if they're available in my region yet. We were one of the last to get the Aries. My largest is a C-Dragon Venus model 6201N, no Herc's, and probably won't have any. Thanks for the model numbers though.
                      • Silvertoast
                        • Feb 2010
                        • 270
                        i would suggest the hercules series also. very reliable and easy to maintain, and can handle the 100k+ a month. personaly dont think the 623 ect would be a good idea for that high a volume. thats just my opinion and experience . i service several of both series.
                        • copyguy1
                          • Jul 2011
                          • 142
                          The other thing to consider is how long will the customer want to keep the machine. I think the hercules will last longer in that respect. We have had some issues with the fuserlasting in the Mx623 machines.
                          • lky1978
                            • Mar 2009
                            • 483
                            dragon series are pretty good, Hercules are awesome.
