MAC OSX, Sharp copiers and account codes.
  • MHeon71
    • Oct 2008
    • 489
    In Window drivers, there is job handling for setting up account codes. In the MAC OS drivers, is there a place where I can do the same. I cannot find it.
    Thanks for any help.
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Re: MAC OSX, Sharp copiers and account codes.
    TT-20218.pdf
    I hope that helps somewhat
    sigpic
    • mnicklin
      I am assuming you are wanting to save an account code? If so, open up a text editor, spreadsheet, or other application and click on print. I'm sorry, my memory is a little foggy, but I believe "Job Detail" is what you are looking for. From there you will see a list and job handling will be an option. Please keep in mind, that I don't have one in front of me and my instrcutions might be slightly off. I do know that you have to actually select print. Don't try to access the printers utility from system settings. Also, keep in mind that the new Adobe Reader version uses a different print applet than other applications.
