Sharp AR 650
  • monham
    • Jun 2012
    • 16
    [Jamming] Sharp AR 650
    I am called to work on a Sharp AR 650 that is jamming before the fuser. However when I attemp to enter into simulation to see which particular sensor is been triggered, I cannot get into simulation. I know that to enter into simulation for the sharp machines it is Programme then interrupt; clear then interrupt but this seems not to work on this machine. Can somebody please help me to get into simulation on the AR 650 copier.Thank you in advance, monham.
  • mrfixit
    Senior Technician
    • Sep 2007
    • 83
    Re: Sharp AR 650
    That machine is actually a toshiba I believe, You won't get anywhere in simulation mode without a book, it doesn't tell you anything like a Sharp does. Fuser gears break often though.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Sharp AR 650
      Paul@justmanuals.com
      • bilyahn
        • Dec 2006
        • 1470
        Re: Sharp AR 650
        Mrfixit is correct it is a Toshiba. You should be getting an Exxx code when the unit jams, hold down the "C+8" to get this code. Do you happen to know the number? To get into simulation mode is pretty easy, hold 0+8 when starting up but as mentioned above without the service manual it won't do you much good. There are a ton of simulation numbers.
        Good luck
        Bil
