Working on an Sharp Ar-m355N
This seems to happen (when it happens) at anytime, start shading the copies/scans and gets worse till it is almost un-readable. I Cked for errors, none listed. Properly power off and back on and it functions correctly. It will be very inconcistant. Some times it will go for several months and sometimes it will do it several times in a day. It's in an office on its own circuit with a surge protector, not near any outside doors, stable , clean enviroment.
I have inspected the cable and conectors, ran an ohms pin out on the same, removed scanner board and scanner interface board, inspected both boards. I see no defects (not that a visual inspection is worth much to a board) Cked ccd as what I can for that. Nothing noticable.
Any body come across this.
Sample included.
Sample included.
