Mx-5110N
  • whoopsy20
    • Aug 2025
    Mx-5110N
    Does anyone know the secret code to get into the test commands on a Sharp Mx-5110N, there is no CA button. Thanks in addvance
  • harleyrider
    • Oct 2011
    • 348
    Re: Mx-5110N
    yes
    • whoopsy20
      Re: Mx-5110N
      I know the other machines use # * CA # but this machine doesnt have CA, could you help a fellow tech out.
      • harleyrider
        • Oct 2011
        • 348
        Re: Mx-5110N
        I have never seen a Sharp that uses #*CA#.
        • whoopsy20
          Re: Mx-5110N
          How do you adjust the DV refference on a MX-5110N
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            Re: Mx-5110N
            OP is asking for the elevated sim commands. Not the regular sim commands. There is #*C* for regular sims and (not releasing) for the elevated commands.
            This model as far as anyone knows does not have an elevated sim command menu. I've been told by a Sharp representative that there may be special firmware involved in accessing elevated commands, others have heard otherwise, but nobody knows how, if at all possible, to access the elevated sim commands.
            • whoopsy20
              Re: Mx-5110N
              Thanks for that informantion, sorry for the way I worded my OP, our machine has very light black and white copies but color copies are good, we will have to give something else a try.
              Thanks again
              • harleyrider
                • Oct 2011
                • 348
                Re: Mx-5110N
                Elevated test commands are not needed to set dv ref. If he is a Sharp tech he can get them from the manual or in class or by video on IDNC.
                • Akitu
                  • Oct 2010
                  • 2595
                  Re: Mx-5110N
                  Thanks again
                  Try executing a shading adjustment with sim 63-2.
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Re: Mx-5110N
                    Paul@justmanuals.com
                    • kri2304
                      Re: Mx-5110N
                      Check how much dev left in dev tank. 51ppm have a problem with pressure in dev thank (sharp says its happening only on K, but we have few cases with one of the colours). There is TB for that. You need to change dev tank top cover with biger filter(looks like mx 3501type), empty dev, put fresh one, change mc or complete drum unit, do the full calibration and should be ok.
