How To Reset Webpage to dafault
  • redserv
    • May 2010
    • 307
    hey guys,Does anyone know how to clear all the settings from a MFP webpage to is default?scan settings, Address Book,Doc Filing etc...Thanks in Advance
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: How To Reset Webpage to dafault
    To help out next time, clone a new machine and use that as a default. You can also clone a used machine after you have set it up the way you want and use that as your default.
    • redserv
      • May 2010
      • 307
      Thanks for the Tip Zootech, any idea how i can make it default after information has been set up already?
      • bilyahn
        • Dec 2006
        • 1470
        There is no easy way. There is a tech tip/bulletin on the procedure to do this but can't find it on Sharpnet (as usual it seems lately) search function is useless unless you have the exact wording. When I have to do it I just go into each section and delete what it there. You can get rid of a lot of stuff by resetting NIC and reformatting HDD but not everything. If I can find the TB I'll post it later.
        Good luck.
        Bil
        • bilyahn
          • Dec 2006
          • 1470
          Found it. It's a tech tip for the MX series.
          TT-20379.pdf
          Good luck.
          • redserv
            • May 2010
            • 307
            thanks buddy appreciate this, it will be very helpfull
