printer Warning in Sharp AR-m350u ..
  • boofe_binaa
    • Jul 2025
    hello
    i have a sharp AR-M350u copy work fine but printer not work ..
    i installed sharp remote device management but is saw only warning .
    i can connect sucecfully with LAN to Sharp device but i can not print with that on lan ..
    can you please help me what do to fix this issue ?
    link is http://78.38.124.254/SRDM/
    thank you
  • lky1978
    • Mar 2009
    • 483
    ar-p14 printer expansion kit installed?
    • boofe_binaa
      Re: printer Warning in Sharp AR-m350u ..
      it worked before good but after i change on code *#c* start 80 then 9 start .. this problem apears ..
      • boofe_binaa
        Wonder full ..
        with parallel port it work good but with LAN it not work ..
        any idea ??!!!
        • bilyahn
          • Dec 2006
          • 1470
          Re-enter the product key for the print controller.
          Good luck.
          Bil
