Sharp MX-2700N Document Feedewr ear marking paper occassionally
  • patterson70
    • May 2010
    • 599
    Originals in the adf getting bent sometimes, not on all originals but it does go in batches sometimes. The origianals are in good condition. There is also a gear grinding in the adf occassionally. There is no information on the document feeder in the service manual for some reason. Has anyone seen a particular reason why it is only occassionally bending the paper in the upper left just a little but not on all pages? I did replace the three adf feed rollers but it did not solve the problem. Machine has about 220K on it. Thank you in advance!
  • Guest
    Re: Sharp MX-2700N Document Feedewr ear marking paper occassionally
    look at the screws on left hinge and check if there is some space between the hinge and the base tray
