sharp arfx7
  • rods
    • 23
    sharp arfx7
    Trying to install arfx7 fax kit in arm317 copier getting error A001 security incompatibility error.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: sharp arfx7
    There's a discrepancy in your serial numbers in your EEPROMs. Have you swapped any boards or is this a new installation? Do you have the AR-MM9 Fax Expansion Memory?
    For future reference, the more details you can provide the better others can assist you.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: sharp arfx7
      You have the DSK installed and need the flash ROM from the kit for the fax to work. That's not a problem if whomever installed the DSK taped the extra ROM in the machine for future install of the fax.
      • rods
        • 23
        Re: sharp arfx7
        Fax kit was out of copier we do not kow what model it came from,we think that perhaps it came from a copier that had a data security kit installed and it is looking for that software.Does make any sense.
        • rods
          • 23
          Re: sharp arfx7
          Thank you theDSK is the problem
