L4-11 error code and noise
  • hammer
    • May 2008
    • 111
    Hi All, I've come across a nasty one and am wondering if you can help out. I have an error code L4-11 on an MX-M182D. It occurs when I switch on the copier, and the shift motor moves to the rear. It appears to not want to stop, makes a grinding noise, then throws up the code. We had something similar before and it turned out to be the MCU PWB, so naturally I went for that. It wasn't the answer. I have changed the shift motor assembly which also contains the home position sensor and no joy.
    Any ideas?
  • mojorolla
    The Wolf
    • 2583
    Re: L4-11 error code and noise
    Most Sharps will give that code if the finisher is unplugged at power up.
    • hammer
      • May 2008
      • 111
      There's no finisher involved.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        L4-11: Content Shifter motor trouble.
        The shifter home position detection signal is not detected when initializing the shifter.
        Shifter motor abnormality, improper connection or disconnection of the harness, shifter home position sensor abnormality.
        Check and remedy:
        Use SIM 03-11 to check the shifter motor operations.
        Check connection of the harness/connector of the shifter motor.
        Replace the shifter motor.
        Replace the MCU PWB.
        • hammer
          • May 2008
          • 111
          Thank you for that, but I've seen the service manual. We had something similar a while ago and it turned out to be the eprom. This was on a brand new device that was faulty out of the box. The device that we have now gas done a couple of hundred prints before showing the fault.
          Any other ideas?
          • bilyahn
            • Dec 2006
            • 1470
            Have you cleaned the shift assembly shaft? They tend to bind have also had the small metal flange that holds the assembly follower rollers together on the front side come loose causing similar problems.
            Good luck.
            Bil
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
