Alright This will be a long post post likely.... here it goes I apologize in advance.
First Trip - We have a Sharp MX-5111n that has dumped/pulled its black developer (Could not find the cause we just refilled the DV and checked everything and it work since then)
Second Trip - Color was Misaligned Horribly and the Bulletin below help fix that issue
Models:
MX-2310U/MX-2610N/MX-3110N/MX-3610NThis is the text from a Sharp bulletin:
MX-4110N/MX-4111N/MX-5110N/MX-5111N
Priority:
Medium
Date:
March 2012
Subject:
Data_SUB_K_F_1ST_ 10 Error
Symptom:
Data_SUB_K_F_1ST_ 10 error when running Simulation 50-22.
Solution:
If this error occurs when running Simulation 50-22, use the below steps to recover.1. In Simulation 50-20 enter default values (200) for A through I, then press Execute.2. Then run Simulation 50-22 and adjust each screw for each color as directed by the Simulationresults. When turning the screws be sure to use clicks not turns.If problems continue replace the laser unit.
Third Trip - We had a a F2-43 Code on the yellow DV Unit and the toner output reading on the yellow dv where as low as 70-82 while the others where at 128-130 so we ordered a sensor and replaced it and now the error is gone...but also so the customer could still print we disabled the color for print and copy and then re enabled them after the sensor replacement and now when we try and make a copy or print color it only prints black and white and basically Ignores that it has Color Anything there are 100-75% color toner in them and it reads 25-0% and we have done a firmware upgrade and now the Black is reading 25-0% sometimes also on our 22-6 report it says (In bold is the weird part)
Drum Ctrg K: 28147 Turn:109803 Day:36 Life: 18% Remain: 0150
Drum Ctrg C: 6842 Turn:81674 Day:485 Life: 9% Remain: ---
Drum Ctrg M: 6842 Turn:81674 Day:485 Life: 9% Remain: ---
Drum Ctrg Y: 6842 Turn:81674 Day:485 Life: 9% Remain: ---
And Developer States the Same Thing Expect now after upgrade all dv counts where cleared without us doing it?
So i reviewed the site and found some of the similar issues of spiking etc i just wanted to see if anyone of you think we should replace the dv units dv, drums etc. appreciate your help in advance
Models:
Priority:
Medium
Date:
March 2012
Subject:
Symptom:
Solution:
