PASSword ADMIN
  • pesar_taha
    • Mar 2011
    • 24
    PASSword ADMIN
    what is password admin ?
  • CrapAimer
    • 296
    Re: PASSword ADMIN
    Try
    Sharp or admin
    • bilyahn
      • Dec 2006
      • 1470
      Re: PASSword ADMIN
      Looks like you are trying to save a file to a PC is this correct?
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Re: PASSword ADMIN
        Originally posted by CrapAimer
        Try
        Sharp or admin
        On the ARM series, it's Sharp.
        • ZOOTECH
          Senior member of CRS
          • 3376
          Re: PASSword ADMIN
          I believe he is looking for the password for those saved documents on the HDD. In order for the default admin password to work he will have to enable the admin to delete "users, files, or folders" in document management. (but I could be wrong again)
          • Akitu
            • Oct 2010
            • 2595
            Re: PASSword ADMIN
            You could be right, it's hard to tell from the 6 word original post.
            • aosservice
              Re: PASSword ADMIN
              try Sharp (with a capital S) or admin (all lowercase)
              • pesar_taha
                • Mar 2011
                • 24
                Re: PASSword ADMIN
                yes im save to file pc
                • RRodgers
                  • Jun 2009
                  • 1947
                  Re: PASSword ADMIN
                  Hello kind sir's
                  I have O so much question on me password.
                  If you give me answer it would be oh sooo nice.
                  Thank for the gratful times.
                  • bilyahn
                    • Dec 2006
                    • 1470
                    Re: PASSword ADMIN
                    The password will then be the user account number that it was saved to the HDD under or you can use the default key operator password of 00000 (unless that has been changed then you can find the code under sim 22 sub 7). That should work for you.
                    Good luck.
                    Bil
