Sharp mx-2600n streaks
  • stevee104
    • Mar 2007
    • 214
    I have a sharp machine that puts magenta and black lines across the page in different spots, the line can be thin at times and ticker at times. It has the hacksaw charge coronas that i clean and it will go away for maybe 250-500 pages before the lines return. I have look in the service manaul at some of the codes to run on the machine at can't see anyting for the charge grids.I have clean the machine ,change the black and magenta drums,blades and new charge grid and the problem returns to soon.page count for black is
    200,456 and color 91,873
  • miv
    • Jan 2013
    • 5
    can you paste scanned print?
    TapatalkSGSAdvance
    • stevee104
      • Mar 2007
      • 214
      Re: Sharp mx-2600n streaks
      This was what i was copying and this was off of there machine with no lines, i put in where the lines was
      showing up. i sorry i don't have the origanals because i was so upset for not fixing it i left in a hurry and left
      them behind. the lines i put in are magenta lines.
      • rolin
        Looks like charge units to me. You say you did replace the MX-310mk? If so, I can see your frustration.
        One of the reasons it looks like charge units is because the lead edge margin is there. If it were a blade or belt unit, the lines would not be erased in the margin.
        Good luck.
        • harleyrider
          • Oct 2011
          • 348
          looks like corona to me also. I normally replace the unit instead of cleaning it.
          • stevee104
            • Mar 2007
            • 214
            yes all units where change 18,000 copies ago, so that why im suprised they are causing this issue so soon.
            • miv
              • Jan 2013
              • 5
              But this is a copy, right? print from codes 64 has the same lines?
              sorry, stupid question but necessary ;-)
              18000 is not 'so soon' ;-)
              • gwaddle
                • May 2009
                • 782
                Looks more like optics to me, because it doesn't go to the edge of the page like a charge line would.
                I know I should be ashamed of myself. Strangely though, I am not.
                • stevee104
                  • Mar 2007
                  • 214
                  it also doing it on prints , no streaks on scans.
                  • gwaddle
                    • May 2009
                    • 782
                    Well never mind then.
                    • stevee104
                      • Mar 2007
                      • 214
                      Here some more samples after i change all the charge grids in all 4 drum units. one is a copy and the other is a internal print this was done 6000
                      copies ago. As you can this has been going on sometime and all the black copies and prints are find.
                      • Akitu
                        Legendary Frost Spec Tech
                        • Oct 2010
                        • 2595
                        Stupid question, but have you used the slit glass cleaning brush on the front door?
                        • copyguy1
                          • Jul 2011
                          • 142
                          This may seem silly but you keep saying you replaced the charge grid. But did you you replace the complete charge assembly
                          • stevee104
                            • Mar 2007
                            • 214
                            yes the whole unit
