MX-3501N code L4-31
  • im44ffx
    MX-3501N code L4-31
    Sharp MX-3501N: Anyone knows what L4-31 service call is for and how I can fix it?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX-3501N code L4-31
    It's a problem with the paper exit cooling fans located above the fuser in the delivery unit. Run TC6-2 to fine which one is failing; we usually replace both at the same time.
    • DavePo
      • Jul 2008
      • 303
      It also could be the toner cooling fans. See attached bulletin. MFP-SB-154.pdf
      • im44ffx
        Thank You...
