Not all the time, but the client was saying that the color was not right on prints and copies. Performed sim 64-1 and changed a to 11 to print out all four colors and the very first one came out fine. So I went back to copy mode and tried to copy a very colorful original and yellow was missing. Went back to 64-1 and tried again and yellow was missing. I tried swapping the magenta and yellow drum units and it stayed with yellow. Placed a piece of tape over the grid and tried to make a skyshot using just 1 color and got a blank sheet of paper. Stopped the process in mid stream and had a solid band on the drum, so charge is indeed working. Swapped the LSU with one from a returned machine and same issue. Swapped PCU, MFP and MFP mother board and still getting the same thing. The MFP was Sharp's idea. The only thing I haven't mentioned is if you cycle the power, yellow will come back for 1 set or 1 copy, but as soon as you try a second set or copy, it is gone again.
Anyone see anything like this before?
