Sharp MX-2310
  • GeorgeBest
    • Jul 2009
    • 525
    Sharp MX-2310
    Customer wants te print from USB stick.
    The scan to USB is functioning allright but when trying
    to print from the USB there is no "extern data" option in the document archive mode. (?)
    There's bin created a black and a collar account. Black account is the default.
    Setting this accounts is the reason for disabling the "extern data" or do I need more options
    No much experience on this one
    anyone ? Thanks in advance
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp MX-2310
    To be able to print from a USB drive they need the postscript kit installed.
    • lky1978
      • Mar 2009
      • 483
      to enable print from usb device,you need to purchase printer expansion kit for jpeg , and postscript kit for pdf .
      • ZOOTECH
        Senior member of CRS
        • 3375
        Re: Sharp MX-2310
        Only certain file types (TIFF, JPEG, PRN, TXT, PDF, AND Encrypted PDF) can be printed and as Akitu says a PS option is needed for some file types.
        • manjunathskm
          Re: Sharp MX-2310
          For all the U Models Printer Expansion Kit MX-PB14 required for direct printing from USB flash. But,
          again if you want to print PDF files you need to add MX-PK11
          • Akitu
            • Oct 2010
            • 2595
            Re: Sharp MX-2310
            I was a little quick to jump the gun on this thread. The posts that followed mine were of greater detail. I don't have a 2310 and forgot it's a U model by default. Cheers to the other guys who filled in the blanks I left!
