MXC311 distortion
  • Nachoman4life
    • Oct 2007
    • 212
    MXC311 distortion
    This is copy and printmxc311 22-6 distortion self print.pdfmxc311 color print distortion.pdfmxc311 copy bw distortion.pdf a few scans i tried looked ok.
    So far nothing has been changed out on the machine, I have cleaned the controller area out, removed and reseated all memory and roms.
    I am leaning toward the mother pwb. Just tossing this one out here in case anyone has seen it before.
    Where the heck is my spring hook?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MXC311 distortion
    Originally posted by Nachoman4life
    This is copy and print[ATTACH]20066[/ATTACH][ATTACH]20068[/ATTACH][ATTACH]20069[/ATTACH] a few scans i tried looked ok.
    I had something similar, it turned out to be a LSU connector problem.
    Run TC 61-4 as this test is from the LSU control board, not the MFP, mother, or PCU pwb.
    • mojorolla
      The Wolf
      • 2624
      I have seen this three times on Frontier series and all were due to a bad LSU.
      • Nachoman4life
        • Oct 2007
        • 212
        Thanks for the info guys, I had LSU running around in the back of my head too (since the scans were fine). I guess I'm just really lucky and haven't had any LSU issue with the entire MX series. This is an extremely low vol machine in a metal shop. (less than 30k on a 4 year old machine)
        • Bani
          • 34
          Hi,
          I have seen this many times, it is not a bad LSU, it is only a dirty polygon motor.
          • DavePo
            • Jul 2008
            • 305
            Originally posted by Bani
            Hi,
            I agree We have one in a welding shop that was getting dirty quite regularly. We took out the laser unit cleaned it all up then ran a bead of silicon around all the seams and wire harness passages to the interior. Sealing it up stop the migration of dirt onto the polygon mirror completely.
            • Nachoman4life
              • Oct 2007
              • 212
              The Lsu did it, thanks for the info. I'll probably clean up and seal the one I took out and use it as a spare.
